on 27-01-2024 14:04
Hi I have ordered M500 and Mixit TV package and I would like to ask if I get the Hub 3, Hub 4 or even Hub 5.
Thank you
Mahir
Answered! Go to Answer
on 27-01-2024 15:00
The current Hubs for the M500 tier are as you stated. You will get either a 3, 4 or 5 depending on stock levels.
on 27-01-2024 15:00
on 29-01-2024 15:17
Hey mahikhan, thank you for reaching out and as mentioned below you will get one of either.
The Hub5 are for 1GB so most likely it will be 3 or 4.
Matt - Forum Team
New around here?
