Hub3 overheat
ML5
My hub has a solid red light. I have switched it off and done a factory reset today and a couple of weeks ago but nothing has changed. It is not in a particularly warm room and well ventilated
6 REPLIES 6
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
I have done three pin hole resets and it stays red. Thanks for your advice
Hi there @ML5 👋 Welcome to our forum and thanks for your post 😊
Sorry to see you've been having issues with your Hub overheating and having this red light. Thanks for doing the checks we'd usually advise to do. As this hasn't changed things, we'd need to arrange an engineer so they can check this for you. I'll pop you a PM to confirm your details so this can be done.
Nathan
Thanks!
i read on the internet the hub 4 has a fan in it
 is that correct ?
Hi there @bhaskarsamani 👋
This is correct, it does have a fan. All specifications for our equipment can be found here.
Nathan
