CJ38
12 months agoOn our wavelength
Hub connection
Is there a maximum length for the broadband cable that connects the hub to the box where it enters the house
Simple answer no. Long answer is the total length of cable from the street box to hub has a limit, but I don’t know what it is. Unless you are a very long way from the street box the internal cable can be any length, but if it increases the technician may have to make adjustments at the street box to move you to another ‘tap’.
