- Roger_GoonerAlessandro Volta
The app is notoriously flaky. What do you want it to do?
- Client62Alessandro Volta
Manage the VM Hub at http://192.168.0.1/ login with the Hub Password ( i.e. not the Wi-Fi password )
The VM Connect app does appear to lead to quite needless tinkering with the VM Hub. - Megan_LForum Team (Retired)
Hi Philriley67,
Thanks for your post and welcome back to our Community Forums 🤗
Sorry the Connect App is not working for you. There are a few things you can do to help, as well as following the advice from Roger_Gooner & Client62.
- Reinstall the app.
- Delete cookies & Cache from the app.
- Use a different device to see if this helps to connect.
If none of these steps help then we would recommend following the VIP's advice as a work around.
Can we ask if you're concerned with your broadband performance and that's why you're wanting to use the Connect App?
Meg
Related Content
- 10 months ago
- 1 month ago
- 6 months ago
