Markyboy1969's avatar
Markyboy1969
Hub 5 timer
Is it possible to set a time for internet to come on/off for kids?
  • goslow's avatar
    goslow
    The features that were built in to the hub
    https://www.youtube.com/watch?v=1zgC5WJc2To
    may not work reliably any more with some modern devices and can easily be bypassed by tech savvy kids. Don't know if the Hub 5 has equivalent features.
    Depending on the age of your kids, and the devices they are using, you might be better limiting access on the device itself.
    Teenagers will inevitably find a way of bypassing whatever measures you implement to a greater or lesser extent.
  • jpeg1's avatar
    jpeg1
    Google "how to bypass parental controls", or any similar phrase.
    or see the video instructions on YouTube.
    For absolute certainty with kids, this could be the only viable option ...
    • Tudor's avatar
      No. Only viable option is to remove the child’s device and lock it in a Faraday cage.
  • I assume you have a virgin media connection. Please be patient and that feature will show up soon enough. You won't be able to choose the devices that cannot connect, or indeed the times, but given a chance you will soon have a connection that prevents Internet access for indeterminate periods on random devices.
    The only problem is, once enabled it can never be disabled.
