Hub 5 constantly drops out in modem mode
We had a hub 5 installed a few months gonas the old hub 4 constantly kept failing. However just lately we are having excessive dropouts all day and night.
we have it in modem mode as have some devices that won't work as they need 2.4.ghz we have a nighthawk router which we had with the hub 4 and now the hub 5.
recently we notice that we are connected to the WiFi however there is no internet access and so many of our internet based devices in the house are losing connections.
on some devices it is happening 6 hourly to the second all day every day and some devices like the iPad and phones they regularly drop out all day and night every day. We've rebooted the hub and our router numerous times it helps for about an hour then it starts again.
ive logged into the hub 5 in modem mode and downloaded the logs but it's all gibberish to me but the words critical make me feel we have some major issues going on here.
can anyone enlighten me or help me please before I throw the blasted hub out the window !!!
Cable Modem Status
| 22-04-2024 21:35:17 | notice | GUI Login Status - Login Success from LAN interface |
| 22-04-2024 21:34:25 | notice | GUI Login Status - Login Fail from LAN interface |
| 22-04-2024 14:57:41 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:41 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:41 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:41 | warning | Dynamic Range Window violation |
| 22-04-2024 14:57:37 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
| 22-04-2024 14:57:37 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:37 | warning | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:27 | warning | Dynamic Range Window violation |
| 22-04-2024 14:57:27 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:27 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:27 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:21 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:18 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:15 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:57:13 | notice | Honoring MDD; IP provisioning mode = IPv4 |
| 22-04-2024 14:57:01 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:56:55 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 22-04-2024 14:56:55 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
| 21-04-2024 08:11:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 21-04-2024 08:11:13 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 21-04-2024 08:11:12 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
| 14-04-2024 12:50:46 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 14-04-2024 12:50:45 | critical | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 14-04-2024 12:50:39 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 14-04-2024 12:50:38 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
| 04-03-2024 08:31:30 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 04-03-2024 08:31:30 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3 |
