on 03-05-2024 12:20
Any best practice / lessons learnt for hub 5 which can be passed forward? Thanks. Just got mine today (replaced hub 3 which i am sending back).
03-05-2024 12:22 - edited 03-05-2024 12:22
If it don't work out for you theirs aways modem mode
on 03-05-2024 12:34
Disable "Smart Security" in the VM Connect app
on 03-05-2024 12:42
I do not have it turned on but neither did i know about it nor bothered to look so it forced me to explore it. Thanks!
03-05-2024 12:52 - edited 03-05-2024 12:52
No better advice than to always run in modem mode, gets over nearly all the quirks/problems with the Hub5.
on 03-05-2024 13:29
We live in interesting times and as such if it’s not fit for purpose as described as a quality router with its service charges to match then I’ll be deferring to Martin Lewis lol
WiFi improvement has been observed so I’m content.
04-05-2024 08:25 - edited 04-05-2024 08:28
If a Hub 5 is issued to us we will have a 3rd Party Router here ready to meet and greet it.
We are not interested in dealing a Sagemcom's software quality issues where is takes months to years to fix some defects only to introduce more new defects. Configuration management and testing staff need not apply.
