pure-skill's avatar
pure-skill
Hub 5 Corrected error rate
Recently had new Hub 5 sent.  Tried to avoid changing from old hub but VM insisted when I renewed contract.
This one reboots sometimes around 2am which is annoying.  It is in modem mode.
Checked the logs, and noted that in downstream status, Corrected errors (Active Profile) seems high.  Did 2 5 minute tests - one at load (downloading .iso at 12-16 MB/s) and one pretty idle:
- downloading iso - 5 minutes - 2,697,664 errors
- mostly idle - 5 minutes - 1,698,056 errors
I appreciate some errors, corrected by checksum or whatever are normal.  But these seem super high.  Would I be correct in that thinking?
  • Anonymous's avatar
    Anonymous
    This question comes up now and then. The answer is that it is normal. The corrected codeword counter for OFDM can increase at any rate without it being sign of issues.
  • pure-skill's avatar
    pure-skill
    Also noted following in log:
    30-10-2024 11:39:29warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=<redacted>;CMTS-MAC=<redacted>;CM-QOS=1.1;CM-VER=3.1;
    30-10-2024 11:39:29warningDynamic Range Window violation
    Item Status TypeChannel Overview Downstream Upstream
    Cable Modem StatusOnlineDOCSIS 3.0
    Primary downstream channelLockedSC-QAM
    DOCSIS 3.0 channels325
    DOCSIS 3.1 channels11
    3.0 Downstream channels
    14110000007.941QAM 2561
    24190000007.541QAM 2562
    34270000007.440QAM 2563
    44350000007.440QAM 2564
    54430000007.140QAM 2565
    64510000006.940QAM 2566
    74590000006.540QAM 2567
    84670000006.540QAM 2568
    94750000006.740QAM 2569
    104830000006.540QAM 25610
    114910000006.740QAM 25611
    124990000006.840QAM 25612
    135070000006.840QAM 25613
    145150000006.940QAM 25614
    155230000006.840QAM 25615
    165310000006.940QAM 25616
    175390000007.341QAM 25617
    185470000007.441QAM 25618
    195550000007.641QAM 25619
    205630000007.441QAM 25620
    215710000007.541QAM 25621
    225790000007.341QAM 25622
    235870000007.241QAM 25623
    245950000007.241QAM 25624
    25603000000741QAM 25625
    266110000006.941QAM 25626
    276190000006.841QAM 25627
    286270000006.240QAM 25628
    29635000000640QAM 25629
    306430000006.140QAM 25630
    316510000006.341QAM 25631
    326590000006.441QAM 25632
    1Locked41260
    2Locked4140
    3Locked4030
    4Locked4020
    5Locked4020
    6Locked4030
    7Locked4040
    8Locked4060
    9Locked4050
    10Locked4080
    11Locked4030
    12Locked4010
    13Locked4030
    14Locked4040
    15Locked4020
    16Locked4030
    17Locked4120
    18Locked4100
    19Locked4130
    20Locked4120
    21Locked4120
    22Locked4140
    23Locked4110
    24Locked4130
    25Locked4100
    26Locked4120
    27Locked4130
    28Locked4060
    29Locked4050
    30Locked4070
    31Locked4180
    32Locked4110
    3.1 Downstream channels
    159944K1840QAM 40961108
    159Locked438.11702482140
    3.0 Upstream channels
    04960000042.85120QAM 641
    14310000042.85120QAM 642
    23660000042.35120QAM 643
    33010000042.35120QAM 644
    423600000425120QAM 645
    0ATDMA0000
    3ATDMA0000
    4ATDMA0000
    3.1 Upstream channels
    61037.02KQAM 256
    6OFDMA200740000000
    0
    pure-skill
    Hub deployed early hours of 16 October 2024, so
    170248214  /14.5/24/60/60
    = 135.89 average errors per second for 14 and a days though of course for periods of the day there is no Internet use at all.
    Though this is low compared to the 2 5 min tests I did today:
    2697664  /60/5 = 8,992.2  errors per second
    1698056  /60/5 = 5,660.18 errors per second
      pure-skill
      I've had 200 million over 14 days.  Surely that can't be right.
    Some time ago, I had a Hub 5, in modem mode, and the errors were colossal !  I'm talking tens of millions.  In the end, I managed to get the Hub replaced via this forum, by posting the evidence, and the replacement was fine.  There is a thread here somewhere about it all.
    EDIT - Found the old thread here Solved: Hub 5 Strangeness .... - Virgin Media Community - 5413274
    pure-skill
    Made a script to monitor the hub, and log corrected error rate.
    13:10:07 30-10-24 194843481 301.20 2474010 8213.75
    13:15:07 30-10-24 197345281 300.00 2501800 8339.31
    13:20:07 30-10-24 199464774 300.01 2119493 7064.76
    13:25:06 30-10-24 201625188 299.60 2160414 7211.08
    13:30:07 30-10-24 203933597 301.01 2308409 7668.99
    Runs every 5 minutes.  Last figure is errors/second
    pure-skill
    OK the corrected error counter was likely 0 at 2am or so after hub rebooted and already nearly up to 600 million.
    I don't fancy trying to explain this over the phone to non tech people.
    Can I get support on this forum?
    <time/date>   <total corrected errors>  <secs since last check>    <errors per second>
    <snip>
    22:05:07 30-10-24 563523072 300.49 3261838 10855.10
    22:10:06 30-10-24 566907345 299.97 3384273 11281.95
    22:15:07 30-10-24 570327223 301.38 3419878 11347.27
    • Carley_S's avatar
      Carley_S
      Hi pure-skill
      Welcome to the community forums.
      Sorry to hear you're having issues with your Hub 5 since installation.
      Checking the systems on our side we cannot see any issues that might be causing this, however, we've limited checks when a router is in modem mode.
      Do you get the same issues when the Hub is in router mode at all?
      If you've also a broadband quality monitor we can take a look at the live link to see if anything is flagging on there to investigate further.
        pure-skill
        Thanks for the reply.
        Is my public IP likely to change if I change router modes?   I appreciate it is not a static IP service, but I'll have to mess with my public DNS if so.
        Could you confirm the massive corrected error rate is unusual?  I have a script that logs it from the router.
        12:15:07 01-11-24 791267461 300.03 2484281 8280.22
        12:15:07 02-11-24 1577252674 301.18 1891894 6281.51
        So in last 24 hours there's been
        1577252674 -791267461    = 785,985,213  errors (or 9097 per second as an average)
        Last self reboot was 2:35ish 31-10-24    (the corrected error counter resets to 0 hence why the negative numbers)
        02:30:07 31-10-24 668064986 301.48 993805 3296.38
        02:40:08 31-10-24 472028 601.49 -667592958 -1109900.15
        Monitor:
        https://www.thinkbroadband.com/broadband/monitoring/quality/share/fb5cefed2da5086e9bded1bd8884106f2b2cb730
        Only 24 hours or so of data - had set up a day before but icmp was blocked until I permitted that IP.
        Thanks!
    Anonymous
      pure-skill
      Thanks for this - I did wonder.
      Will see how the rebooting issue goes.
