Roger_K's avatar
Roger_K
Dialled in
Hub 5 Broadband Port
Just received a hub 5 to upgrade from my hub 3. Didn’t think I needed it but it came with my new package.  My broadband is now “Volt Gig 1” which is supposed to be between 1052 and 1136 Mbps. VM’s connection instructions don’t say which port I should connect my PC to so I’ve gone for the 2.5Gbps. Any disadvantage to this?  I’ve connected the Netgear Powerline going to the TV to one of the other ports. Should they be the other way around? Thanks for any advice.
1 Reply
