Magoo19's avatar
Magoo19
3 years ago
Hub 5 5 and 2.4 ghz band help
I have a hub 5 and I am trying to setup some new Wi-Fi plugs which require 2.4ghz. I found a post which explained how to rename the 2 ghz so I could set up the plugs and lights.  However  my app is asking me to optimise my network and wants to move it back to one name. As soon as I do this the devices that are connected to the other Wi-Fi stop working. There also appears to be no option in app to cancel the need to do this.
Any help would be appreciated, I am a complete novice at this.
    Seriously totally ditch the VM Connect app
    Login in to the Hub 5 management menu at http://192.168.0.1/
    Disable Smart Wi-Fi aka Wireless Channel Optimization
    Disable 5 GHz Wi-Fi
    Now connect all your plugs and lights
    Re-enable 5GHz Wi-Fi
    I'd leave Smart Wi-Fi aka Wireless Channel Optimization Disabled, it is more trouble than value.
  • Hey Magoo19, thank you for reaching out and I am sorry to hear this.
    I can see some advice has been posted above this, did this manage to help or do you still need some help on this? Cheers
