- jbrennandVery Insightful Person
What Hub model is it (printed on its base sticker) ?
- Jpa-JpaJoining in
Hi, it’s a 3.0
- Gareth_L
Hello Jpa-Jpa.
Thanks for your post.
Sorry to hear about the issue with your Hub3, losing connection and having the red light.
I can look into this for you.as we will need to arrange an engineers visit to replace the Hub3.In the meantime, Can you make sure the Hub is well ventilated and away from any direct source of heat.
If you can check the logo top right of your screen that would be great.
Gareth_L
