on 29-03-2024 15:27
Since December, my Hub 3.0 crashes every day. Sometimes it recovers / restarts itself, sometimes I have to restart it using the rocker switch on the back. It takes ~10 minutes to get back online each time. I'm not sure how to troubleshoot this...
I don't believe it's overheating, as it's not in a small space, its in fresh air on top of a cupboard.
The last time it happened was today, around 2:30pm (I think..)
I'll post my log files, in case they're useful.
Thanks in advance!
Andy
on 29-03-2024 15:27
Acquired Downstream Channel (Hz) | 203000000 | Locked |
Ranged Upstream Channel (Hz) | 23600000 | Locked |
Provisioning State | Online |
1 | 203000000 | 7.1 | 40 | 256 qam | 9 |
2 | 211000000 | 7 | 40 | 256 qam | 10 |
3 | 219000000 | 7 | 40 | 256 qam | 11 |
4 | 227000000 | 6.8 | 40 | 256 qam | 12 |
5 | 235000000 | 6.8 | 40 | 256 qam | 13 |
6 | 243000000 | 6.5 | 40 | 256 qam | 14 |
7 | 251000000 | 6.3 | 40 | 256 qam | 15 |
8 | 259000000 | 6 | 40 | 256 qam | 16 |
9 | 267000000 | 6 | 40 | 256 qam | 17 |
10 | 275000000 | 6 | 40 | 256 qam | 18 |
11 | 283000000 | 5.9 | 40 | 256 qam | 19 |
12 | 291000000 | 6 | 40 | 256 qam | 20 |
13 | 299000000 | 5.9 | 40 | 256 qam | 21 |
14 | 307000000 | 6 | 40 | 256 qam | 22 |
15 | 315000000 | 6 | 40 | 256 qam | 23 |
16 | 323000000 | 6 | 40 | 256 qam | 24 |
17 | 331000000 | 6 | 40 | 256 qam | 25 |
18 | 339000000 | 6 | 40 | 256 qam | 26 |
19 | 347000000 | 6 | 40 | 256 qam | 27 |
20 | 355000000 | 6 | 40 | 256 qam | 28 |
21 | 363000000 | 5.9 | 40 | 256 qam | 29 |
22 | 371000000 | 5.8 | 40 | 256 qam | 30 |
23 | 379000000 | 5.6 | 40 | 256 qam | 31 |
24 | 387000000 | 5.9 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 5 | 0 |
2 | Locked | 40.3 | 6 | 0 |
3 | Locked | 40.9 | 0 | 0 |
4 | Locked | 40.3 | 6 | 0 |
5 | Locked | 40.3 | 4 | 0 |
6 | Locked | 40.9 | 8 | 0 |
7 | Locked | 40.3 | 5 | 0 |
8 | Locked | 40.3 | 6 | 0 |
9 | Locked | 40.9 | 5 | 0 |
10 | Locked | 40.9 | 6 | 0 |
11 | Locked | 40.9 | 6 | 0 |
12 | Locked | 40.3 | 5 | 0 |
13 | Locked | 40.3 | 6 | 0 |
14 | Locked | 40.3 | 5 | 0 |
15 | Locked | 40.3 | 6 | 0 |
16 | Locked | 40.9 | 7 | 0 |
17 | Locked | 40.3 | 1 | 0 |
18 | Locked | 40.9 | 5 | 0 |
19 | Locked | 40.9 | 0 | 0 |
20 | Locked | 40.3 | 6 | 0 |
21 | Locked | 40.3 | 6 | 0 |
22 | Locked | 40.9 | 5 | 0 |
23 | Locked | 40.9 | 5 | 0 |
24 | Locked | 40.3 | 0 | 0 |
on 29-03-2024 15:28
1 | 23600000 | 40 | 5120 | 64 qam | 9 |
2 | 36600000 | 40.8 | 5120 | 64 qam | 3 |
3 | 30100000 | 40.3 | 5120 | 64 qam | 4 |
4 | 43100000 | 41 | 5120 | 64 qam | 2 |
5 | 49600000 | 41.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 29-03-2024 15:28
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt057+voc-b.cm |
SFID | 255980 |
Max Traffic Rate | 143750047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 255979 |
Max Traffic Rate | 22000047 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 29-03-2024 15:29
29/03/2024 15:04:40 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/03/2024 14:54:32 | notice | NOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/03/2024 02:16:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/03/2024 08:15:29 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/03/2024 14:25:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:59:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:59:12 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:52:15 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:52:11 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:50:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:49:1 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:33:6 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 14:32:54 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 13:52:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 13:52:10 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 13:50:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 13:50:40 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 13:48:48 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/03/2024 13:48:48 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 29-03-2024 15:41
Check the log entry for : 29/03/2024 14:54:32 that could be a clue as to the problem with the Hub 3.
on 01-04-2024 13:31
Great spot, thank you. I've read that this can be related to a CPU failure. Any idea how I go about getting a new hub?
I tried pin hole resetting in Jan, and it hasn't fixed the problem.
on 01-04-2024 13:44
Hi NinjaAndy,
We're sorry to hear you've been having issues with your hub. We've done some checks on the hub from this end and have not found any issues that could account for hub rebooting and connection drop-outs.
We need you to complete a Pin hole reset of the Hub in an attempt to resolve any unfound issues. Do this by holding a pen in the reset hole on the back of the Hub for 30 seconds. This will reboot the Hub and reset all Hub settings to default. If you have made any changes to the Hub's wireless settings you may need to reconnect your wireless devices to the Hub as the WiFi settings will now be back to default.
Please let us know how this goes or if you have any further issues.
