How to order WiFi pods?
RevJC
Hi there,
I'm also looking to order a WiFi Pod to boost my WiFi upstairs if possible - I am on Volt and have a 1GB connection so am hopefully eligible.
Thanks for your help 🙂
James
1 ACCEPTED SOLUTION
Accepted Solutions
Ilyas_Y
Thanks for speaking with us today @RevJC on the VM forums, 👋🏼
I'm glad we have been able to assist in ordering out the Wi-Fi pod.
As advised - it will arrive next week although with New Years and NYE being today and tomorrow, some deliveries may be delayed slightly.
Let us know if there's anything else we can do to assist and we'll support where we can.
Kind regards,
Ilyas.
Ilyas_Y
5 REPLIES 5
Ilyas_Y
Hey @RevJC Thanks for reaching out to us and a warm welcome to the Virgin Media Community forums. 👋🏼
We will certainly be able to assist you in relation to your queries for the Wi-Fi pods.
I will be sending a private message to further assist and get this sorted out for you, 😇
Kind regards,
Ilyas.
Ilyas_Y
Ilyas_Y
Kind regards,
Ilyas.
Ilyas_Y
Superb, thanks very much for your help with this. Brilliant customer service 👏
Hi @RevJC
Thanks for coming back to the thread. There are a few requirements for the Pods to work with our Hubs:
•    The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'.
•    Channel Optimisation must be left on.
•    The SSIDs must be the same and broadcast enabled.
•    The SSID must be password protected.
•    The Passphrases of the SSIDs must match.
As long as all of the above points are all met then the Pod should automatically connect to your Hub's Wi-Fi and begin broadcasting. The wireless details from the Pod will be the same as the Hub's details, so no additional steps are required to connect the devices in the home.
This link will help though if you do have any issues: https://www.virginmedia.com/help/setup/intelligentwifipod
John_GS
Cheers John, I'll come back if I have any difficulties.
