willows2
2 years agoTuning in
High ping spikes pls help
I keep getting ping spikes over 244ms randomly.
My hub stats have been checked and they are good.
Is it possible is a neighbour is connected to your line that it can cause latency issues?
hub stats
3.0 Downstream channels
| 1 | 370000000 | 8.9 | 38 | QAM 256 | 2 |
| 2 | 362000000 | 9.3 | 39 | QAM 256 | 1 |
| 3 | 378000000 | 8.4 | 39 | QAM 256 | 3 |
| 4 | 386000000 | 8 | 38 | QAM 256 | 4 |
| 5 | 394000000 | 7.9 | 38 | QAM 256 | 5 |
| 6 | 402000000 | 7.8 | 38 | QAM 256 | 6 |
| 7 | 410000000 | 7.8 | 39 | QAM 256 | 7 |
| 8 | 418000000 | 7.7 | 39 | QAM 256 | 8 |
| 9 | 426000000 | 7.6 | 39 | QAM 256 | 9 |
| 10 | 434000000 | 7.5 | 38 | QAM 256 | 10 |
| 11 | 442000000 | 7.4 | 39 | QAM 256 | 11 |
| 12 | 450000000 | 7.5 | 39 | QAM 256 | 12 |
| 13 | 458000000 | 7.3 | 39 | QAM 256 | 13 |
| 14 | 466000000 | 7.2 | 39 | QAM 256 | 14 |
| 15 | 474000000 | 7.1 | 39 | QAM 256 | 15 |
| 16 | 482000000 | 7 | 39 | QAM 256 | 16 |
| 17 | 490000000 | 6.9 | 39 | QAM 256 | 17 |
| 18 | 498000000 | 6.7 | 39 | QAM 256 | 18 |
| 19 | 506000000 | 6.5 | 39 | QAM 256 | 19 |
| 20 | 514000000 | 6.6 | 39 | QAM 256 | 20 |
| 21 | 522000000 | 6.5 | 39 | QAM 256 | 21 |
| 22 | 530000000 | 6.5 | 39 | QAM 256 | 22 |
| 23 | 538000000 | 6.5 | 39 | QAM 256 | 23 |
| 24 | 546000000 | 6.4 | 39 | QAM 256 | 24 |
| 25 | 554000000 | 6.4 | 39 | QAM 256 | 25 |
| 26 | 562000000 | 6.3 | 39 | QAM 256 | 26 |
| 27 | 570000000 | 6.5 | 39 | QAM 256 | 27 |
| 28 | 578000000 | 6.3 | 39 | QAM 256 | 28 |
| 29 | 586000000 | 6.2 | 39 | QAM 256 | 29 |
| 30 | 594000000 | 6 | 39 | QAM 256 | 30 |
| 31 | 602000000 | 6 | 39 | QAM 256 | 31 |
The lines to you and your neighbours are connected together in the street cabinet.
Having said that your service is generally good according to the BQM. Many people get spikes like that very frequently at busy times. I doubt that you would get much support from VM.
