Jellybelly69's avatar
Jellybelly69
3 years ago
HUB 4 VPN Issues
Had Hub 3 changed Upgraded to Hub 4 Oct 23 , unable to connect to VPN either wireless or cabled for work, ISP address on 3 is was exactly the same as 4, works message says failed IP.address locked? Not a clue they cannot fix it how do I keep WFH when needed
  • Change hub to modem mode
    also change DNS to 1.1.1.1, 8.8.8.8 or what ever you like should that be the problem
  • legacy1's avatar
    • Jellybelly69's avatar
      Jellybelly69
      I will try this though I'm not technically savy one bit and come back thanks
  • Hey Jellybelly69,
    Welcome back to the community and thanks for taking the time to post.
    I’m sorry to hear of the issues that you’re having with your hub 4 and VPN, are you still having the issues at the moment or has the help offered by legacy1 been able to resolve your connection issues?
    Kind Regards,
    Steven_L
      Jellybelly69
      Hello only just seen responses I will try and then come back to you
        Jellybelly69
        Can access now but only via Ethernet cable and not via WiFi ie cable less any reason why? My it states its a provider issue
