sawin's avatar
sawin
12 months ago
Ethernet cuts out for around 10 seconds at random points in the day.
Hey there! Every 30 mins to an hour or sometimes even every few hours my internet cuts out (I am using an ethernet cable) I have tried plugging in my ethernet to other slots in the router and I have also turned off channel optimization.
It doesn't really seem like a big issue at first and its something that ive been dealing with for about a month now. I play online games and obviously there are punishments for disconnecting from matches mid game. And this makes it almost impossible to play a game without reciving long bans for disconnecting etc.
If anyone has any suggestions on how to fix this please let me know.
Note - I dont know exactly what router im using but when I go to login to the settings page it says "Hub 4" Thats the most I know
Thanks!
  • jbrennand's avatar
    ok- can you do this...
    _________________
    First thing is to check for any “known network faults in your location - Look in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    ________________
    If nothing is reported there, post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    ____________
    THEN Also, If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
