Ethernet Connection Disconnects (20 seconds at a time) - Various Points In The Day
Hello,
As the title suggests, for the last 3-4 months my ethernet on my desktop PC has been dropping at various points in the day. I suspect it may have something to do with my Hub 5.
Tonight (06/07/2024 @ around 10 pm) I had a couple of disconnects in a row. I may only get 1 disconnect on some days, but on others, I may get 1 - 2 an hour.
I have:
- Replaced the ethernet cable.
- Checked for outages in my area.
- Reseated each cable into the router and tried each individual ethernet port.
- Resetting the router.
Unfortunately, nothing has worked. Here are my downstream, upstream and network logs:
3.0 Downstream channels
| 1 | 331000000 | 0.6 | 41 | QAM 256 | 25 |
| 2 | 195000000 | 1.6 | 40 | QAM 256 | 8 |
| 3 | 203000000 | 1.2 | 40 | QAM 256 | 9 |
| 4 | 211000000 | 1.4 | 41 | QAM 256 | 10 |
| 5 | 219000000 | 1.4 | 41 | QAM 256 | 11 |
| 6 | 227000000 | 0.9 | 40 | QAM 256 | 12 |
| 7 | 235000000 | 0.7 | 40 | QAM 256 | 13 |
| 8 | 243000000 | 0.4 | 40 | QAM 256 | 14 |
| 9 | 251000000 | 0.1 | 40 | QAM 256 | 15 |
| 10 | 259000000 | 0.1 | 40 | QAM 256 | 16 |
| 11 | 267000000 | 1 | 41 | QAM 256 | 17 |
| 12 | 275000000 | 1.6 | 41 | QAM 256 | 18 |
| 13 | 283000000 | 1.7 | 41 | QAM 256 | 19 |
| 14 | 291000000 | 1.5 | 41 | QAM 256 | 20 |
| 15 | 299000000 | 1.5 | 41 | QAM 256 | 21 |
| 16 | 307000000 | 1.5 | 41 | QAM 256 | 22 |
| 17 | 315000000 | 1.3 | 41 | QAM 256 | 23 |
| 18 | 323000000 | 0.9 | 41 | QAM 256 | 24 |
| 19 | 339000000 | 0.6 | 41 | QAM 256 | 26 |
| 20 | 347000000 | 0.3 | 41 | QAM 256 | 27 |
| 21 | 355000000 | 0.1 | 40 | QAM 256 | 28 |
| 22 | 363000000 | 0.1 | 41 | QAM 256 | 29 |
| 23 | 371000000 | 0.4 | 40 | QAM 256 | 30 |
| 24 | 379000000 | 0.9 | 40 | QAM 256 | 31 |
| 25 | 387000000 | -1.1 | 40 | QAM 256 | 32 |
| 26 | 395000000 | -1.1 | 40 | QAM 256 | 33 |
| 27 | 403000000 | 0.9 | 40 | QAM 256 | 34 |
| 28 | 411000000 | 0.9 | 40 | QAM 256 | 35 |
| 29 | 419000000 | 0.8 | 40 | QAM 256 | 36 |
| 30 | 427000000 | 0.6 | 40 | QAM 256 | 37 |
| 31 | 435000000 | 0.4 | 40 | QAM 256 | 38 |
| 1 | Locked | 41 | 0 | 0 |
| 2 | Locked | 40 | 0 | 0 |
| 3 | Locked | 40 | 0 | 0 |
| 4 | Locked | 41 | 0 | 0 |
| 5 | Locked | 41 | 0 | 0 |
| 6 | Locked | 40 | 0 | 0 |
| 7 | Locked | 40 | 0 | 0 |
| 8 | Locked | 40 | 0 | 0 |
| 9 | Locked | 40 | 0 | 0 |
| 10 | Locked | 40 | 0 | 0 |
| 11 | Locked | 41 | 0 | 0 |
| 12 | Locked | 41 | 0 | 0 |
| 13 | Locked | 41 | 0 | 0 |
| 14 | Locked | 41 | 0 | 0 |
| 15 | Locked | 41 | 0 | 0 |
| 16 | Locked | 41 | 0 | 0 |
| 17 | Locked | 41 | 0 | 0 |
| 18 | Locked | 41 | 0 | 0 |
| 19 | Locked | 41 | 0 | 0 |
| 20 | Locked | 41 | 0 | 0 |
| 21 | Locked | 40 | 0 | 0 |
| 22 | Locked | 41 | 0 | 0 |
| 23 | Locked | 40 | 0 | 0 |
| 24 | Locked | 40 | 0 | 0 |
| 25 | Locked | 40 | 0 | 0 |
| 26 | Locked | 40 | 0 | 0 |
| 27 | Locked | 40 | 0 | 0 |
| 28 | Locked | 40 | 0 | 0 |
| 29 | Locked | 40 | 0 | 0 |
| 30 | Locked | 40 | 0 | 0 |
| 31 | Locked | 40 | 0 | 0 |
3.1 Downstream channels
| 41 | 94 | 4K | 1840 | QAM 4096 | 1108 |
| 41 | Locked | 38 | -6.3 | 19119073 | 0 |
3.0 Upstream channels
| 0 | 49600000 | 48.5 | 5120 | QAM 64 | 4 |
| 1 | 43100000 | 48.5 | 5120 | QAM 64 | 5 |
| 2 | 36600000 | 48.8 | 5120 | QAM 64 | 6 |
| 3 | 30100000 | 48.5 | 5120 | QAM 64 | 8 |
| 4 | 23600000 | 48.3 | 5120 | QAM 64 | 11 |
| 0 | ATDMA | 0 | 0 | 0 | 0 |
| 1 | ATDMA | 0 | 0 | 0 | 0 |
| 2 | ATDMA | 0 | 0 | 0 | 0 |
| 3 | ATDMA | 0 | 0 | 0 | 0 |
| 4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
| 12 | 10.4 | 44.0 | 2K | QAM 256 |
| 12 | OFDMA | 208 | 74000000 | 0 |
| 06-07-2024 23:14:31 | notice | GUI Login Status - Login Success from LAN interface |
| 06-07-2024 23:10:36 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
| 06-07-2024 23:10:32 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:10:26 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:10:19 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:10:16 | notice | Honoring MDD; IP provisioning mode = IPv4 |
| 06-07-2024 23:10:02 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:10:01 | critical | Cable Modem Reboot because of - Reboot Timezone Change |
| 06-07-2024 23:07:32 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:06:44 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:06:23 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:06:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:06:14 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:02:13 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:01:29 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
| 06-07-2024 23:01:18 | critical | Cable Modem Reboot because of - Reboot Factory reset ACS |
| 06-07-2024 23:01:18 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
I also had some network logs prior:
Router status
StatusDownstreamUpstreamConfigurationNetwork Log
Refresh data
06-07-2024 23:14:31 notice GUI Login Status - Login Success from LAN interface
06-07-2024 22:10:36 notice REGISTRATION COMPLETE - Waiting for Operational status
06-07-2024 22:10:32 notice US profile assignment change. US Chan ID: 12; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:10:26 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:10:19 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:10:16 notice Honoring MDD; IP provisioning mode = IPv4
06-07-2024 22:10:02 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:10:01 critical Cable Modem Reboot because of - Reboot Timezone Change
06-07-2024 22:07:32 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:06:44 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:06:23 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:06:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:06:14 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:02:13 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:01:29 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 22:01:18 critical Cable Modem Reboot because of - Reboot Factory reset ACS
06-07-2024 22:01:18 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
