Deco mesh modem mode on hub
Mydogsam
I recently installed T - Link deco mesh to boost my wifi coverage . So I logged into my hub 3 to disable the hub Wi-Fi ,  to do this I have to choose modem mode this disables the router wifi. Thing is when you do this only Ethernet port number 1 remains active the others are turned off . So if like me you have anything connected to ports 2 3 or 4 they have no connection. I have looked at buying a Ethernet switch to overcome this . I don’t think I should have to do this surely virgin should be able to fix this .
10 REPLIES 10
Thanks for all your help my mesh system is working perfect with the switch
