2 weeks ago
My hub 3 is showing a red power light instead of the usual white power light. It is solid red but the hub is not overheating and is kept in open space.
There is a a drop out in wifi connection on all devices off and on throughout the day.
Elsewhere in the forum I can see a replacement hub is needed..... is there someone here who can arrange that for me rather than having to jump through all the hoops!?
2 weeks ago
Hey Sean_P, thank you for reaching out and I am so sorry to hear about this.
I am going to send you a DM but in the meanwhile please do try these steps;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Matt - Forum Team
New around here?
2 weeks ago
Thank you for this but all of the above has been tried
a week ago
I can see we've already sorted this within in a private message.
Keep us updated 🙂
Matt - Forum Team
New around here?
Sunday
Yes, all sorted. An engineer came round to replace the box
For others who may see this post, apparently they can't just send a new box now as a previous post mentioned, an engineer has to deliver it.
Tuesday
Hello Sean_P.
Thanks for your update.
Glad to hear everything is working perfectly after the hub was swapped.
Should you need anything else at all? you know where we are.
Gareth_L
