Taslima's avatar
Taslima
Can't order WiFi pods
My kitchen and bedrooms have very poor Internet (usually 350kbps - 15mbps) after doing the home scan but it won't let me order the wifi pods. Can anyone help?
  • Zach_R's avatar
    Zach_R
    Hi Taslima,
    I'm sorry to hear that you're having some trouble with the reach of your WiFi, and that you're also struggling to order a WiFi Pod to help remedy this. What happens exactly when you attempt to order a Pod via the app?
    • Taslima's avatar
      Taslima
      Every time I do a home scan it says I have bad connection but there is no option to order a WiFi pod.
      • Ashleigh_C's avatar
        Ashleigh_C
        Thank you for confirming Taslima
        Can I ask what speed is shown on the scan? Can I also just check are you following these checks:
        ·         Tap Start the scan
        ·         Then Start the scan again
        ·         While connect to WiFi, Tap I’m ready
        ·         Wait 2 mintues for Scan
        ·         Scan complete, Tap continue
        ·         Tap Add a room, Tap the room you're in
        ·         Start the Scan (do this in every room)
        ·         Scan complete
        ·         Tap Optimise WiFi now if an option
        ·         If so, Tap Optimise
        ·         Optimisation complete, Tap Rescan room,
        ·         Tap Start Scan
        ·         Tap Order a WiFi Booster if an option
