865178
  • 6
Message 1 of 49
Best router for Hub 3 modem mode?
Among the experts on this forum, can I ask what is the best performing router to work with a Virgin Hub 3.0 set in Modem Mode so that the broadband passes through the virgin hub and is then transmitted by a more sophisticated and better performing router? Hope that makes sense?
I was looking at a Netgear Nighthawk X6 but then i see many forums saying that the wi-fi seizes up every few days needing a hard reset. Thx in advance.
Sephiroth
  • 21.88K
  • 626
  • 3.74K
Message 2 of 49
Re: Best router for Hub 3 modem mode?
I and a lot of others use the ASUS brand; a range of well spec’d routers that differ only in their WiFi capabilities.
Springer1
  • 75
  • 5
  • 17
Dialled in
Message 3 of 49
I have an Asus 66,  not a expert here, but am pleased to report that my hair is now growing back, lost while suffering a stock hub 3 thing. lol ..........
865178
  • 6
Message 4 of 49
ok so some more google searching and yes indeed Asus looks like the winner in terms of positive reviews and minimal issues or cries for help...
I'm looking at the Asus RT-AC3200 as ideally don;t wish to spend over £200 but are there any experts here that would argue a better alternative? specifically to work with Hub 3.0?
griffin
  • 11.8K
  • 1.08K
  • 2.57K
Message 5 of 49
I would consider the specs and number of wireless clients you wish to connect.
The Asus RT-AC3200 is a Tri band router which has two 5Ghz radios, which is great if you have a lot a 5Ghz clients connecting the same time. but not much use if your 5 Ghz requirements are modest. In this case a cheaper Dual band router may suit your requirements better.
The RT-AC3200 is pretty high specced with 3 antennae on both 5Ghz band and 4 on the 2.4Ghz band. To get full benefits of the higher spec your wireless clients need to match the same spec.
As said, the Asus is a well repected brand and all fibre versions should work with the Hub 3 with the minimum of configuration, it is just a question of budget and your requirements.
  • 22.33K
  • 2.4K
  • 3.98K
Message 6 of 49
http://www.expertreviews.co.uk/networks/wireless-routers/1403819/best-wireless-routers-improve-your-...
MarieTW681
  • 18
Message 7 of 49
https://badmodems.com/Forum/app.php/badmodems
Full list of bad modems here
tonycv51
  • 603
  • 28
  • 113
Rising star
Message 8 of 49
 All will be good but look at Asus AC86U  - now about £160.  Newer CPU than the other Asus Routers, newer wi-fi chips etc. but not so new that you're at the bleeding edge firmware wise https://www.smallnetbuilder.com/wireless/wireless-reviews/33158-asus-rt-ac86u-dual-band-ac2900-wirel...
  • 8.12K
  • 649
  • 1.42K
Message 9 of 49
Are you only looking to improve your WiFi or for extra facilities and many connected cable devices? If it’s mainly WiFi you wish to improve all you really want is a very good Wireless Access Point and it would cost a lot less than £160/£200.
Cheule
  • 136
  • 6
  • 13
Up to speed
Message 10 of 49
I have the RT-AC3200 and since installation it's not missed a beat, been up 42 days solid now.
Vivid 350 - Superhub 3 modem mode --> RT-AC3200
