chappyat27
1 year agoTuning in
Arlo door camera on Hub 5
Due to a problem on the Hub 5 using an app I've had to do a bit of resetting.
The Arlo only works on a 2.4g signal so I'm trying to switch the 5g signal off put all controls are greyed out.
Anyone help me please?
Use the Hub 5 admin menu at http://192.168.0.1/
Login with the Hub Password.
Disable "Smart Wi-Fi" aka "Wireless Channel Optimization" ( or what ever it is called on a Hub 5 )
Now it should be possible to disable the 5GHz Wi-Fi to ensure use of just the 2.4GHz band whilst you perform the configuration of the Arlo.
