JohnHemel's avatar
JohnHemel
Broadband 5G not compatible with wifi door camera?
I have a smartlife wifi camera and set it up fine some months ago with my V hub 3.0
About 3 weeks ago the picture ceased while I was away. Trying to reset it now its saying I have 5G wifi which is incompatible.  I seem to recall my wifi was 2.4 G or similar...    Has some upgrade happened ( I live in HP2)?
Is my camera now scrap?
cheers
  • Set the 2.4Ghz & 5Ghz WiFi Network Name (SSID) to be different.  Then make sure your door camera joins the 2.5Ghz.
    Like this:
