Apple Kit Not Connecting to SH5 Using WPA3
soquas
Hi all - I hope that you're well.
In short, I can't get my iPhone (iOS17.0.3) or iMac (13.4.1) to connect to my recently installed SH5 using WPA3 but WPA2 works fine.
I've searched the forum for WPA3 related posts and there was a rash of them earlier in the year. There appeared to be a known issue with Apple kit not being able to connect to SH5 with WPA3, although there wasn't anything particularly categoric, and I haven't seen anything posted in the last few months which might suggests that it's been resolved. Dunno - please let me know if it has.
I've also tried connecting using the WPA2/WPA3 transitional setting to no avail.
I've tried setting the wireless mode explicitly to 802.11ax, but again no luck.
And yes, whenever I change the security settings on the SH5 I use the 'forget network' functionality on the devices before attempting to reconnect.
I saw something weird too. On my iMac in WiFi | Advanced... | Known Networks my WiFi network is reported as having security type "WPA3 Personal" even though it categorically isn't AND indeed it reports the WiFi networks from my old SH2 as "WPA3 Personal" too, although obviously that's impossible! That looks like a bug, but I thought that I'd make mention.
So, is the inability to connect Apple devices to a SH5 using WPA3 a known issue and if so is there any outlook for a fix? If not, then can someone tell me what I'm doing wrong, please?
Thanks in advance 🙂
17 REPLIES 17
soquas
Ok, thanks - not sure how I missed that and useful info about Android / Windows.
Presumably firmware upgrades are applied automatically, there’s no way to initiate them from the SH itself, is that right?
Yes, VM Hub's do not have a "Check for updates" menu option.
soquas
If someone from the Forum Team sees this then please can you review and give us an update on the issues with WPA3 as detailed above? I think it would benefit a number of people, myself included. Thanks.
soquas
Hi @Travis_M apologies for the bling tag but we're struggling to get any clarity on when this issue will be resolved. Please can you review and let us know?
Many thanks in advance and kind regards 👊.
Is this just with the Apple devices that this is happening with?
If so it will be a firmware upgrade which the team will be working on, your the first person I've come across who this is happening to is it doing it on any other devices at all?
Matt - Forum Team
New around here?
This is not the first report of Hub 5 WPA3-SAE connection failures. We don't see the remarks often as the Hub 5 has WPA3-SAE disabled by default.  ( Loudly hinting it is known to be troublesome )
With either WPA3-PSK only or WPA2-PSK/WPA3-SAE enabled connectivity issues have been reported with Apple kit, recent Android Phones & Windows 10/11 laptops.
soquas
Client62 - Yes, spot on, 100% agreed on all points.
Virgin Media - you need to look into this a provide a fix.
soquas
Ok, I’ve tried again and it’s now working although the router appears to have the same firmware which would suggest that an iOS update has fixed the issue.
As an aside, when attempting to get my Mac to connect to the router with 5Ghz set to WPA3 it kept grumbling that it needed ‘a WPA3 password’ although the password hadn’t changed. When I changed the password to something else it connected ok. It seems, even though I’d ‘forgotten the network’ on the Mac, that it kept some association between the old password and WPA2 and was having none of it with WPA, although my iPhones had no such issue. Odd.
In any case, WPA3 is now working with my Apple kit.
