Advice please. Need to connect existing cable internet connection to new computer
hackneyuser
I have searched site and cant find info.
So after many years I am getting a new Windows computer.
Apart from loss of connection last year (eventually sorted) hub and computer connection all working.
But I realise I have no idea how to connect I new computer.
Do I just plug in the cable currently connected to my old computer into my new computer. Or ... ?
If there is a help page about this happy to try and follow but cant find anything on VM website.
1 ACCEPTED SOLUTION
Accepted Solutions
asim18
Fibre optic
Generally, yes. For wired (Ethernet) devices you can simply unplug the Ethernet cable from your old computer and plug it into your new computer.
Should work straight away.
https://commons.wikimedia.org/wiki/File:Ethernet_Connection.jpg
For your wireless (Wi-Fi) devices you'll need your Wi-Fi password which is usually printed somewhere on your Hub.
4 REPLIES 4
asim18
Fibre optic
hackneyuser
Many thanks for your reply.
I sort of assumed that, and I do have a wired connection.
Which is just as well as I have no idea what my wi-fi password is!
Roger_Gooner
Unless you've made a change the WiFi SSID and password are on a label on the hub.
Note: My username is Roger_Gooner and not Alessandro Volta
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Thanks for that info about password.
I should have realised as I have used that to link a set top (tv) box to my hub!
