- Client62Alessandro Volta
When the Hub 4 is in Router mode (i.e. you have Wi-Fi enabled on the Hub) , you can add as many 10/100 or better 10/100/1000 Networks switches as are needed and make use of all available ports i.e from both the VM Hub and the network switches. (We have a Hub 3 + TP-Link 8 Port 10/100/1000 network switch).
For a Hub 4 in Modem mode, attach a network switch to the LAN side of the 3rd Party Router. - Donfor40Superfast
Thanks I thought I had immediate helpful answer.
Which 3rd party router, I disconnected Nighthawk ages ago, does this need to be re used if adding new Switch.
I've fixed my typo ... does that help ?
- Donfor40Superfast
Thanks it was additional router that I didn't think of.
Maybe I'll re add Nighthawk at some point.
Great to see Every port can be used with Hub and Switch.
thanks
The Nighthawk, if configured in access point mode would it do the job of giving additional network ports ?
Related Content
- 9 months ago
- 2 years ago
- 12 months ago
