groovebox's avatar
groovebox
3 years ago
Landline switch to hub not working
Received adapter.
Received text saying to switch & re-boot hub.
I've plugged the adapter into the Hub & plugged the phone into the adapter. Rebooted the Hub (3.0), Hub status says "Telephony (ready)" but I can't make or receive calls.
What do I do now?
  • Zach_R's avatar
    Zach_R
    Hi groovebox,
    Thank you for your post and welcome back to our community forums. We're here to help.
    I'm so sorry to hear you're having some trouble with your landline service following the local switchover. I've checked things over on our systems and I'm unable to detect a fault currently to explain this.
    What happens when you attempt to make a call? Are you hearing a dial tone when you put the phone to your ear?
    • Paul_DN's avatar
      Paul_DN
      Hi groovebox,
      Thank you for reaching back out, sorry to see you still have no dial tone over 24 hours after the switch, have you plugged the phone back in the wall socket to see if the switch has took place?
      Paul.
  • No dial tone on the old wall socket. I tried an old non-cordless phone in the wall socket and although there was no dial tone the phone was powered enough to generate tones when the numbers were pressed. When I plug it into the hub I don't even get that. Does it matter which of the 2 "tel" sockets on the hub I use? (I assume I should be using those and not one of the 4 network sockets)
    • Paul_DN's avatar
      Paul_DN
      Hi groovebox,
      The Adaptor goes in the top 2 sockets, not all phones may work, how old is the handset you have, you can find out more here.
      Paul.
  • Hi Paul,
    Its a Gigaset C300. 10 years old. I don't want to buy a new handset. Will Virgin Media supply one or switch me back to the landline?
    The FAQ you directed me to says: "Will I have to change my home phone? No, you can keep using the same phone you’ve always used. "
    • Paul_DN's avatar
      Paul_DN
      Hi groovebox,
      Thank you for coming back to me, the phone probably isn't within spec to support it, are you able to try a different phone, maybe a friend or family member to make sure it is that?
      Paul.
  • What's the process for switching back and not using the hub?
    • John_GS's avatar
      John_GS
      Hi groovebox
      The telephone exchanges are closing, so it's not an option to revert back to the wall socket I'm afraid.
      Best wishes.
  • @Paul_DN  Can you help me please to get landline working, we have relatives in and out of hospital, ect and we are desperate to get the landline working.
    Switch over date was messaged to me and confirmed it had taken place, to this day no phone signal. Can not get through to technical for support, tried over a few days, very poor. I have reset Hub5, plugged in BT phone line into back of router, still no ring tone.
    All pre-sales and communication was brilliant and the instal technicians were fantastic (Comex contractors for Virgin). Regretably phone number migration had not been processed so I would have to wait 7-10 days.
    I really didn't want to believe all the negative comments about after sales support, but beginning to believe it now.
  • John_GS
    • Robert_P's avatar
      Robert_P
      Hello Eyelife
      We're sorry to hear of the issues regarding the landline since the change to working via the Hub, we appreciate you taking the time to raise this via the forums.
      Have you been able to speak to the team in regards to this? If so, what have we advised when you have spoken to us? Who advised of the 7-10 day timeframe to resolve this?
      Rob
  • So I've just gone out and spent £40 on a Panasonic KX-TGC422. Plugged it in and its saying "check phone line" on the handset screen. Still unable to make calls. I've checked the connections (adapter into hub, phone line into adapter and phone line into handset base-station) and everything is plugged in securely. What now?
    • Gareth_L's avatar
      Gareth_L
      Hello groovebox.
      I think it's best if we got one of our technicians round to take a look and get your line up and running.
      If you can check the Logo top right of your screen that would be great.
      Gareth_L
  • Thanks for sending the technician. Issue was that the adapter needs to be plugged into the TOP telephone socket - port 1 (The 2nd socket is only if you have a 2nd phone number/line). I missed that small but important detail on the instructions. I assumed it was like a network socket so didn't matter.
    Thanks for everyone's responses.
    • Alex_RM's avatar
      Alex_RM
      Thanks for letting us know groovebox,
      Glad to hear things have been resolved 🙂
      Alex_Rm
