Gromit1234's avatar
Gromit1234
Landline dead / Telephony disabled on Hub3
Landline dead, phoned Virgin, they said use the Hub and was sent an adapter for my Hub 3. It doesn't work, checked Hub and got "Telephony disabled" - I need the landline as the Virgin/O2 mobile is rubbish since the switch to O2. Need an engineer to visit.
  • Carley_S's avatar
    Carley_S
    Hi Gromit1234
    Welcome to the community forums
    Sorry to hear that you're having issues with your landline at this time.
    I can see that another forum team member is supporting you on this from a post your made elsewhere.
    Should you have any further concerns at all, please continue with your already opened private message and the agent will assist you from the private message
  • Ok I thought it was out of date as the other comments are from last year
    • Carley_S's avatar
      Carley_S
      No worries Gromit1234
      If you've been responded to by the forums team then we will of course continue to support you on the other thread.
