misterjoint24's avatar
misterjoint24
Replacement stream box
Hello, new user here. I was fitting a new TV the other day and misplaced my stream box, cannot find it anywhere at all. I've had the house upside down, really annoying!
My question is, does anyone know if I can get a replacement from VM and how I would go about getting one?
    • misterjoint24's avatar
      misterjoint24
      Thought so, no worries. I've just found out I can stream the football from the Virgin TV Go website live on my LG TV so I'll just use that for now. If I have to pay at the end of my contract so be it, maybe it will turn up by then.
      Thanks for the reply anyway!
      • stevemorgan's avatar
        stevemorgan
        Superfast
        I hope you find it. These things always turn up when your not looking.
