Steven281180's avatar
Steven281180
3 days ago
Power issue with stream box
My stream box cut out while I was watching it . So I reset it . Now there’s a message on screen saying stream box need more power to start up? Look like it has a fault
1 Reply
  • A couple of things worth checking in the short term
    1. are you using the supplied power lead? I had similar issues with using my own before they sent me the right lead; and
    2. try it without the Ethernet lead attached - i.e. use WiFi if you are currently using Ethernet. That also caused me similar issues at first, albeit again before I had the supplied lead.
