SMD1's avatar
SMD1
Using Virgin Media TV Box to connect PS5 to LAN.
 I’m a little confused, I was not home when my Hub 3 was installed, but the installer said I could get a splitter to connect my PS5 to the internet via a wired connection from the VM TV Box, as I was not present, I’m unsure what he meant. I’m wondering what cable can I split and how do I connect up to get a wired LAN?
  • That's the main feed from the VM network, that the PS5 cannot use.
    You need to run an ethernet cable from the HUB to where your wired devices are located.
  • The 'VM TV Box' doesn't supply an internet connection, only the HUB can.
    Is there an ethernet cable run from the HUB to the TV box?
    • SMD1's avatar
      SMD1
      Hi Carl,
      There is no ethernet cable running at present between the Hub and TV Box.
