simon123321's avatar
simon123321
3 years ago
PS5 connection issue ( work with wifi, but not with Ethernet cable) HUB3
Just moved to Virgin
I had no problem connecting with PSN before
And I have good connections with any other device through wifi ( including PS5)
but if I connect my ps5 with ethernet cable, at first it has an error of failed to obtain IP address ( PS5 error code : CE-109503-8)
therefore I have inputted the IP address manually and it still doesn't connect to playstation network and I have no internet access at all
Can someone help
    • simon123321's avatar
      simon123321
      Basically I have no issue with connecting to Wifi
      tried the fix from playstation and I am able to obtain IP address now, proofing there is some block from my modem itself?
        Nothing has proved it is a Hub 3 issue.
        The WiFi and  Ethernet connections should both work  ( always assuming the network cable is not defective ).
        Unless some port forwarding is configured on the Hub that directs data to the PS5's WiFi IP address.
  • I was just having this issue. PS5 connected via LAN then just stopped working. Would work on WiFi no issues.
    Logged into WiFi router using IP address and password on bottom of the router itself and found that the PS5 LAN had been put onto a MAC Address Filtering list, essentially blocking access. This is found in the Security menu on the left hand side under MAC Filtering. Not sure why or how this happened, maybe from an update on the router or something.
    Deleted it from the list and works fine now.
      This is how the Connect app "pauses" devices.  It may have originated from there?  We have seen posts here where devices have been paused via the app, and the users have had to do this procedure to "unpause" them.
      • Finn3's avatar
        Finn3
        I have never really used the app much, I did check it to see if anything was paused/blocked but didn't see anything.
        I might have just missed it though and took the long route around it haha 👍
