gaz2210's avatar
gaz2210
5 months ago
Port Forward issue with newer Hubs...
I'm trying to port forward, i was given the ports by bethesda for Wolfenstein YoungBlood, I'm host, we've both have 200mbps+ internet, the problem i have is, that I believe was introduced in Hub 3? ( I had Hub1 from 2013-2018 and then after it broke was moved to Hub3 so not sure if it applied for Hub 2) where the ports cannot overlap... so if I do start point 2700  end point 27015, start point 27015 end point 27030, the 27015 is overlapping... would making them as single TCP/UDP 27000-27050 do the same job, or it's better to make several "rules" making sure they don't overlap?
already set up static IP through HDCP in router
( the way i was told to do port forwarding, is if i was given 27014-27050 and 27031-27036 to them separately, don't combine, and with Hub1 it was possible, it wasn't giving any errors)
Steam
TCP / UDP Ports 27000 through 27015
TCP / UDP Ports 27015 through 27030
TCP / UDP Ports 27014 through 27050
TCP / UDP Ports 27031 through 27036
TCP / UDP Ports 27036 through 27037
TCP / UDP Ports 4380
