mrfwibble's avatar
mrfwibble
3 years ago
Work VPN connection issues
Hi, this morning I am struggling to use my works VPN connection over Virgin Media. I have done the usual steps to power off everything, wait and then boot up the router, wait, then boot up laptops etc.
My internet is working fine, streaming 4K YouTube no issues.
Work VPN connection is terrible, using a standard IKEv2 VPN over UDP 500 and UDP 4500.
I am using a 4G SIM hotspot with EE and the works laptop is perfectly fine.
Notice a few other forum posts about similar this morning, is there an issue within Virgin's network ?
    Looking at https://downdetector.co.uk/  the graphs and heat maps for Virgin Media , BT Internet and Plusnet are all oddly similar.
    Hot spots in all the major cities and a ramp up of reported outages this morning.
  • Reece_MH's avatar
    Reece_MH
    Hi mrfwibble,
    Thanks for your post, and welcome back to our Community Forums.
    I'm sorry to hear you've been facing problems with connecting to your work VPN. At the time of your post, we were investigating a problem which caused VPN connections to run slower than expected, or lose connection completely.
    This issue has now been resolved and you should be able to access these services as normal. I'm very sorry for any inconvenience caused.
    How are things since posting?
    • JP19912023's avatar
      JP19912023
      Hi Reece, I have had this issue ongoing since June this year. Previous to June, I did not have issues connected to a VPN using my Virgin wifi, did something change in June? (Currently when connect to Virgin wifi I am disconnected from my company VPN anywhere from 10 to 20 times a day. I do not have this issue when I hotspot to with my O2 mobile)
      What can you recommend to fix the issue?
