lukes___'s avatar
lukes___
Wifi Pods (white) - great tech, shame they're so tetchy
So my first pod (#1), just failed to work at all and was sent back. The replacement one (#2) worked fine first time and I added a second pod (#3) for best coverage.
Worked ca. 1 month - then just stopped.
#1 - when plugged in -> light blue light then blue light / green light / no light then cycles back to blue light. Doesn't get assigned an IP address by VM Hub so basically invisible to the network
#2 = when plugged in -> white led then pulsing white led. No assigned IP address.
(does anyone know what the leds mean - i read somewhere that white pulsing is no network signal?)
Both tested less than 10m from VM hub wifi
So basically, two more dead pods?
  • sorry in the post above should be #2 and #3 in paras 3 and 4
    • John_GS's avatar
      John_GS
      Hi lukes___
      I'll send you a PM now, can you get me the Pod serial numbers please of the ones you are using, for diagnostic reasons.
      Best wishes.
