lindaeccles's avatar
lindaeccles
WiFi pod will not connect to hub
I have had a new WiFi pod delivered last week and it will not connect to my hub 3 no matter what I do. I have been on the phone and on chat to CS with no resolution at all
i Have a previous hub which is connected and working fine , we had a technician out at the time for another issue when we received this pod and he said he had to do something his end to set it up, which he did and since there hace been no issues with the first one.
I have tried to explain this again and again to CS but it’s like I’m talking to a brick wall
 Please help
  • jbrennand's avatar
    Try this first as it may not be activated on you your account.
    Call the equipment activation number on - 0800 953 9500 (follow options) and check with them. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
  • Hey I done this today and the pod seemed to connect and light no longer flashing however on the VM connect it shows that the WiFi pod is offline?
    • Sabrina_B's avatar
      Sabrina_B
      Hi lindaeccles 👋.
      Thanks for reaching out to us, apologies for the issues that you are having with your WiFi Pod. we would need to bring you in for a private message to discuss this and resolve.
      Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
      Thanks.
      Sabrina
