Spinneruk's avatar
Spinneruk
3 months ago
Wifi pod rapid flashing red
I have a white wifi pod, working fine for a bit now no longer works at all.
Turns on then flashes red rapidly.
Have factory reset the hub 5, restarted the pod and nothing.
Done the one thing and says there could be a firmware issue with the pod, then said get a replacement...then tells me one has already been ordered and should have arrived which it hasn't.
How do I go about getting a replacement, called and they couldn't help apparently.
Mark
  • jpeg1's avatar
    jpeg1
    Some of the older white pods hove been known to burn. Does yours feel hot? If so remove it and demand one of the newer black ones to replace it.
    A VM person should pick this up.
    • Spinneruk's avatar
      Spinneruk
      Yeah does get warm I have to say....thanks for that.
      Will wait for a VM bod to get in touch as the guy on the phone said to leave it plugged in for 24 hours for it to connect , did this the other day and left it 3 days...still the same
  • So spoke to someone online, I need an engineer to come out and look at the current pod, however they are sending me a second pod ?  makes perfect sense 🤦‍♂️
    • Tom_W1's avatar
      Tom_W1
      Hi Spinneruk thanks for posting although we're sorry your Pod is causing you issues.
      We appreciate it's been a few days since your issue, can you please let us know if when you get the 2nd Pod if this has resolved the problem or not?
      Many thanks
        Spinneruk
        Second pod works fine, its a white one again and is obviously used by the state of it..given it a clean and looks ok.
        Does get very hot though when turned on so will be turning it off each night just in case.
        Was expecting a new black model.
        Previous pod is sat here doing nothing now.
