Matt451's avatar
Matt451
Wifi 6 on 1gb connection?
Writing for a friend of mine
She has a 1gb broadband package with Volt. She has atrocious wifi speeds on the first floor of her house. There are four people living there, all of them are gamers. She has a hub 4, so no wifi 6 connections. She just spent the best part of an hour talking to support and was fobbed off with just one pod and was told that they wouldn't update her hub.
Is she entitled to a wifi 6-enabled hub with her 1gb package? If so, how can she get one without going via India again?
    The Hub 4 and 5 are the two Hubs supplied by VM for 1 Gb Tier at present.  There is no entitlement to WIFI 6. However with the 1 Gb tier she can get up to 3 WiFi Pods at no extra cost.  Personally the “gamers” would be better off serviced by a switch and cables.
  • nodrogd's avatar
    nodrogd
    You are primarily paying for your speed TO the hub, not for WiFi performance from it. Most ISP provided routers are bog standard level kit. Particularly if you have gamers in the house, you need to look at least at a third party, top of the range router that can handle the high throughput, & put VMs router into modem mode. Directly wired connections are however preferable.
  • jpeg1's avatar
    jpeg1
    Four gamers on Hub4 Wifi?  That's never going to work.
    If you can't wire them all by ethernet, at least run one ethernet to a more central position and fit a decent WiFi access point
    Invest in a suitable Wi-Fi Mesh or some Wi-Fi APs.
    Wi-Fi 6 is intended for Airports & Conference Halls with many hundreds of active devices.
  • legacy1's avatar
    VM don't care about wifi which makes me think why they even try
    VM would make more money supplying a modem free then cost to you a 3rd party router or get your own
    Just how much money is being wasted with router mode and pods that don't help
  • Tudor's avatar
    Any serious gamers use an Ethernet connection. 4 at once would tax any WiFi system.
  • Carley_S's avatar
    Carley_S
    Hi Matt451
    Welcome back to the Community Forums.
    Sorry to hear of your friend's concern with their WiFi.
    I can see that the Community have been able to support you on your queries here. If your friend is on 1Gbps, and their concerns are coverage-related, then our WiFi pods will assist with boosting the signal further into those areas of weak signal.
    You can use the Connect app to check the positioning of the WiFi pods to get the most out of them. They'll need to be placed in an area with a strong signal to be able to boost that signal further.
    Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the Community Forums if needed.
