iurdacosta27's avatar
iurdacosta27
4 days ago
Where to activate Guest WiFi
Before this new update we could turn guest WiFi on and off now seems like it doesn’t work. Was this deleted permanently ?
    In our Hub's admin menu it would be :
    Advanced settings >>> Wireless >>> Guest network
    If you are saying this is no longer present, please mention :
    ++ the model of VM Hub
    ++ the current software version
  • Hi iurdacosta27
    Welcome back to our forums, and sorry to hear you are having issues with the Guest WIFI. We want to best help from here. Are you able to answer the questions posed by newapollo so we can better understand and help?
    • iurdacosta27's avatar
      iurdacosta27
      What? My question is how ti activate Guest Wifi like the previous app before the new update i cannot do it in this new app which its awful.
      • legacy1's avatar
        There is no Guest WiFi...
        For a router with Guest WiFi look to get your own router with 1Gb ports and put hub in modem mode
    Are you talking about turning the guest wifi off via the Connect app, or directly via your hub?
    Which hub do you have?  What was updated and which version is it running?
