Grumble2
1 year agoJoining in
VM Hub 2ac crashes under load
My VM Hub 2ac regularly crashes, usually when under load eg. downloading large files. It is in modem mode with wired connection a router which has wired connections to 2 PCs. The whole internet connection is down, not just wifi. I can see the router on the network and it says it has no internet connection. Wiring directly to the hub doesn't fix it. The only thing that fixes it is restarting the VM Hub. The VM online chatbot sticks to a script and is not helping in this scenario. What can I do?
