madmanx's avatar
madmanx
Dialled in
Virgin upgrade works has messed up power levels
Hi had some work on my local network done today as it says it was doing upgrade work to improve the services,
But after being down for half the day when the hub came back online I saw the power levels are way out if sync now. The downstream before was between 0 and 3dbmv and the upstream dbmv was about 38 dmbv, now the downstream is +10 dbmv and the upstream is now around 34dbmv, do I need an engineer to fix it? I have a 6db forward path attenuater fitted at back of hub which i could change to a 10db forward path attenuator to bring down the downstream power levels but its the upstream I'm concerned about as its only 34dbmv?
Have I a problem now?
Welcome back!
Sign in to view or modify your Hub 3.0 settings.
PasswordShow
Router status
11387500009.838256 qam1
21467500009.538256 qam2
31547500009.538256 qam3
41627500009.538256 qam4
51707500009.638256 qam5
61787500009.538256 qam6
71867500009.538256 qam7
81947500009.638256 qam8
92027500009.638256 qam9
102107500009.538256 qam10
112187500009.638256 qam11
122267500009.638256 qam12
132347500009.838256 qam13
142427500009.638256 qam14
152507500009.838256 qam15
162587500009.838256 qam16
172667500001038256 qam17
182747500009.838256 qam18
192827500009.838256 qam19
202907500009.838256 qam20
212987500001038256 qam21
223067500001038256 qam22
233147500001038256 qam23
2432275000010.138256 qam24
1Locked38.960
2Locked38.660
3Locked38.660
4Locked38.950
5Locked38.670
6Locked38.650
7Locked38.6180
8Locked38.9150
9Locked38.950
10Locked38.960
11Locked38.640
12Locked38.970
13Locked38.950
14Locked38.950
15Locked38.940
16Locked38.650
17Locked38.660
18Locked38.640
19Locked38.950
20Locked38.960
21Locked38.660
22Locked38.950
23Locked38.950
24Locked38.950
