Hi, the modem is currently in its default wifi router mode with a solid white light & most services I use work. It just has some mini incompatibilities with my 3rd party router related to domains.
If I connect & switch it over to modem mode, it goes through the normal process of light cycles & finishes up with a solid green light. However, the same ethernet connection says it has no internet. I'm also unable to connect to the modem using 192.168.100.1 either. I've powered it off & on a few times. However when I unplugged it completely & left it for 5 mins & plugged it back in. It did say for about a minute I had internet & it let me log into the modem, however as soon as I clicked on modem status, it showed a blank box & then I lost connection again.
Nothing to do with the ethernet port as it works in router mode. Swapped out cable to be sure to no effect. It was working & I was in the middle of a game & then I lost internet. I thought it was just a typical router disconnect or update, but half hour later still no internet, went to bed & still no internet. The only way I get it to work is in router mode, it refuses to work in modem mode at all & I need it to work in modem mode.
As for my 3rd party router, nothing wrong with it or it wouldn't be working with the hub 5 in router mode. And I've tried connecting directly & through my 3rd party router with the hub 5 in modem mode, makes no difference.
Something has happened to the hub 5 modem mode. I've reset it a dozen times having tried putting it in modem mode just as many times. Its broke I'd I'd like a replacement.
