mobo99
9 months agoJust browsing
Virgin Hub Modem Mode Question
Hi, can anyone tell me if I put the Virgin hub into modem mode will I be able to use the single working (port 1) Ethernet port to access the internet from my laptop or when its connected to my tv?
Also can I add a 5 port network switch to this single working Ethernet port to allow more connections?
If the above is not possible could or would I have to add a non-wifi modem to the working port on the hub and then use all the ports on the new modem.
The aim of this is to remove wifi as a connection option.
Thank you in advance for your assistance.
