- jbrennandVery Insightful Person
Are you using the VM Hub in modem mode with the X60 doing the routing?
- humgurungJoining in
Hi John,
Yes, I'm using the VM Hub in modem mode with the X60 doing the routing.
HUM
- legacy1Alessandro Volta
if you have configure the pfSense right you just need to power off hub for two mins to allow the MAC change your pfSense WAN has
- Roger_GoonerAlessandro Volta
Why do you want to use pfSense as most don't need it.
You could use pfSense to replace the Deco or, if you want to keep the Deco, connect pfSense to Deco by their LAN ports and configure pfSense in bridge mode.
Roger_Gooner wrote:Why do you want to use pfSense as most don't need it.
Some people like to build a real firewall router that a home router can't do.
Related Content
- 3 years ago
- 1 year ago
- 1 year ago
