AGrosse's avatar
AGrosse
8 hours ago
Throttling / Peering Issues
I'm suspiciously having issues with download speeds from Github and GDrive. I'm talking like less than 1MB/s. This issue goes away as soon as i use a VPN, has anyone else run into this problem?
This is also a non-issue when i tether to my phone on 5G.
My experience with Virgin’s support so far:
  • Initially told a trouble ticket would be raised - no one ever called back. (Back in August).
  • Followed up and was told the ticket had gone to the IT department - again, no call back. (Back in August).
  • Reached the complaints/retentions team - first agent put me on hold for 19 minutes, then disconnected the call.
  • Called again, spoke with another agent who got nowhere and transferred me to the FMS team. They couldn’t even identify the correct IP address I was on and started talking about a random IP supposedly blacklisted by SPAMHAUS, which wasn’t even mine or relevant to my issue.
  • Finally, I was passed to the “Gadget Rescue” team. Easily the least technical team I’ve ever dealt with. After realizing they couldn’t help at all, I ended up hanging up in frustration.
At this point, it feels like Virgin’s customer support doesn’t exist unless it involves sending an engineer or replacing a hub. Honestly, I’m seriously considering moving home just to get out of their service area.
1 Reply
    Network issues that vanish when a VPN is used have in the past pointed to a local VM routing problem.
    With the VPN OFF, if you perform a trace route to the IPs of the servers that are running slow, does the trace route complete ?
