Sudden Slow WiFi Speeds
Hi. Over the last week, the WiFi speed of my broadband has dropped significantly. I am on Volt 350, and I've run the WiFi strength tester in the VM Connect app. It shows that WiFi speed in the living room, which is where the Hub is situated, is very low. I was literally 4ft from the hub. I've tried rebooting the hub, but no difference.
I also ran a test at Samknows.com, which showed similar results.
Samsung Galaxy S20 is dual band so should be much faster.
The next question is what is the Hub 4 doing on the 5GHz band, i.e. is that 5GHz band actually broadcasting despite what may be seen in the Hub 4 menu. The "Wi-Fi Analyser (open source)" app for the S20 should show what is happening on both bands.
if the 5GHz band is not showing up, try the VM Hub's 5GHz band set on manual channel 36 or 44 which should enable it to start immediately.
Check the security is WPA2-PSK and the mixed mode included N & AC.
Use of the older WPA-PSK can stop devices from connecting.
Perhaps also, have the 2.4 & 5GHz bands recently been split and the devices only have Wi-Fi profiles for the slower 2.4GHz band.
