Luka_'s avatar
Luka_
Speed hasn’t doubled?
Hey so a while back I switched over to virgin media after being an o2 customer for a long while now and they said that after 14 days (switched back in February) and still nothing?
alongside this I’m getting no more then 70mbs on my laptop where there should be 274mbs
could anyone recommend help?
    Sounds like you are connecting with 2.4Ghz WiFi?  What does a wired speed test show at this site.  Run the FULL test and post the result please.   www.samknows.com/realspeed
        That shows VM are supplying the full 250Mb Tier to the Hub.  You need to look at the connection from the Hub to your laptop.  If you are using 2.4Ghz Wifi then you will not see anymore than you are getting now.  What speed does a wired connection to the laptop show? If it's still slow, the laptop maybe only using a 10/100 link speed?
