Andygeorge1976's avatar
Andygeorge1976
Settling in
Sonos and smart plugs (2.4ghz network)
Hi. I’ve just switched to Virgin from a previous Virgin Business account where the router had both a 2.4 and a 5ghz network I could connect to. This new router doesn’t show that option but I’m hopeful there is something I can do so that I can connect my Sonos and my smart plugs as they only connect to a 2.4ghz network.
Can anyone assist please?
    • Access your Hub by navigating to 192.168.0.1
    • Login with the default login info (on base of Hub) unless you've already updated it.
    • Go to Advanced Settings > Wireless > Security
    • Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
    • Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
    • Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
    • Disable the Smart Optimisation on the wifi bands.
    NOTE - If you use Pods, this will disable them as they need a single SSID as "out of the box".
