dianelegion66's avatar
dianelegion66
11 days ago
Solid red line on hub
  • Hi, for over a week now my hub 3 has had a solid red line it feels warm but not hot. I have tried all the advice from forums but the solid red line is still there.
  • Hey dianelogion66, thank you for reaching out and we are so sorry to hear about your red line issues. We are going to send you a DM, please do try these steps in the meanwhile;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
  • nodrogd's avatar
    nodrogd
    Most likely a failed LED indicator (they do wear out, causing the Blue & Green components to fail, leaving only red). This is still a safety issue as it could mask a genuine overheat situation, so the hub should be replaced. A member of the forum team should respond to this thread shortly.
