Martan16's avatar
Martan16
Solid red light on hub
I have a solid red light showing on my hub. Tried power cycling but when switched back on solid red light comes back. No WiFi obviously. I’ve now just left the hub switched off.
  • Tudor's avatar
    If it’s a Hub3 it will need replacing, but as you have no broadband service I suspect it’s a hub4 or 5. If it is then a red LED means there is no signal being received by the hub. So, follow this:
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web service status page, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
      • Tom_W1's avatar
        Tom_W1
        Hi Martan16 thanks for posting although we're sorry to hear of your concerns raised.
        We do want to look into this for you so please expect a PM from me to arrive shortly regarding this, and respond directly when you can!
        Many thanks
